Installing ArcGIS Viewer for Silverlight
1638
07-16-2011 06:15 PM
MatthewBoyle
I just downloaded the latest beta version of ArcGIS Viewer for Silverlight and I'm getting the attached  message box when trying to install.  I have IIS enabled and the prerequisite checks for features.  I'm running 64-bit Windows 7.
Any ideas...?
RichardWatson
I haven't a clue what the problem is but you can run msiexec on the msi with diagnostics turned on.
Google on voicewarmup.
RobRahrs
Once I have loaded the software...how do I open the viewer
ErikEngstrom
Try:
http://localhost/Builder/default.htm
DerekLaw
Esri Esteemed Contributor
Hi Matthew,
The error message you're getting was identified as a bug in the ArcGIS Viewer for Silverlight beta 2 setup. A workaround to address this issue was posted on the Esri Beta Community forums:
ArcGIS Viewer for Silverlight Beta forums - Unable to install
(a login is required to access content)
In future, please post comments and questions related to the Silverlight Viewer beta 2 on the Esri Beta Community, as this is where the Dev team is monitoring user feedback.
Hope this helps,
