Insert new feature in a feature service layer via a geocode result.
3294
11
11-03-2011 12:02 PM
MattMiley
Is there away to insert a new feature in a feature service layer via a geocode result?
There isn't much documentation in the Editing Features section of the Concepts Tab in the ESRI Silverlight API. I would just like to take away the need for the user to pick a geographical point on the map to make a new feature and instead just have the feature's coordinates be determined by a geocode result.
Any suggestions on how to achieve this would be greatly appreciated.
PreetiMaske
Please take a look at sample
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#LocationToAddress
All you need to do is tweak the sample a little bit for adding the returned result of the geocoding to a featureservice.
In the codebehind go to in LocatorTask_LocationToAddressCompleted. In this event instead of adding the graphic to the graphic layer, you can add the graphic to your FeatureService(editable FeatureLayer) and call FeatureLayer.SaveEdits() to save the results.
Hope this helps!
MattMiley
Well I managed to get it to create a new feature from a geocode result, But now i can't add attributes to the new feature. I add attributes of the newly created feature in a featuregrid but it won't save. I have to refresh the page atleast once then edit the attributes before it lets me add attributes and save.
How do you update, refresh, and save attributes of the feature layer in code?
using System;
namespace GeoEdit
    public partial class MainPage : UserControl
        Locator _locatorTask;
        GraphicsLayer _candidateGraphicsLayer;
        private static ESRI.ArcGIS.Client.Projection.WebMercator _mercator =
            new ESRI.ArcGIS.Client.Projection.WebMercator();
        public MainPage()
            InitializeComponent();
            ESRI.ArcGIS.Client.Geometry.Envelope initialExtent =
                    new ESRI.ArcGIS.Client.Geometry.Envelope(
                _mercator.FromGeographic(
                    new ESRI.ArcGIS.Client.Geometry.MapPoint(-82.23, 41.48)) as MapPoint,
                    new ESRI.ArcGIS.Client.Geometry.MapPoint(-82.15, 41.4)) as MapPoint);
            initialExtent.SpatialReference = new SpatialReference(102100);
            MyMap.Extent = initialExtent;
            _candidateGraphicsLayer = MyMap.Layers["PointLayer"] as GraphicsLayer;
        private void FindAddressButton_Click(object sender, RoutedEventArgs e)
            _locatorTask = new Locator("http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/TA_Streets_US_10/GeocodeServer");
            _locatorTask.AddressToLocationsCompleted += LocatorTask_AddressToLocationsCompleted;
            _locatorTask.Failed += LocatorTask_Failed;
            AddressToLocationsParameters addressParams = new AddressToLocationsParameters()
                OutSpatialReference = MyMap.SpatialReference
            Dictionary<string, string> address = addressParams.Address;
            if (!string.IsNullOrEmpty(InputAddress.Text))
                address.Add("Street", InputAddress.Text);
            if (!string.IsNullOrEmpty(City.Text))
                address.Add("City", City.Text);
            if (!string.IsNullOrEmpty(State.Text))
                address.Add("State", State.Text);
            if (!string.IsNullOrEmpty(Zip.Text))
                address.Add("ZIP", Zip.Text);
            _locatorTask.AddressToLocationsAsync(addressParams);
        private void LocatorTask_AddressToLocationsCompleted(object sender, ESRI.ArcGIS.Client.Tasks.AddressToLocationsEventArgs args)
            CandidateListBox.Items.Clear();
            List<AddressCandidate> returnedCandidates = args.Results;
            foreach (AddressCandidate candidate in returnedCandidates)
                if (candidate.Score >= 80)
                    CandidateListBox.Items.Add(candidate.Address);
                    Graphic graphic = new Graphic()
                        Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol,
                        Geometry = candidate.Location
                    graphic.Attributes.Add("Address", candidate.Address);
                    string latlon = String.Format("{0}, {1}", candidate.Location.X, candidate.Location.Y);
                    graphic.Attributes.Add("LatLon", latlon);
                    if (candidate.Location.SpatialReference == null)
                        candidate.Location.SpatialReference = new SpatialReference(4326);
                    if (!candidate.Location.SpatialReference.Equals(MyMap.SpatialReference))
                        if (MyMap.SpatialReference.Equals(new SpatialReference(102100)) && candidate.Location.SpatialReference.Equals(new SpatialReference(4326)))
                            graphic.Geometry = _mercator.FromGeographic(graphic.Geometry);
                        else if (MyMap.SpatialReference.Equals(new SpatialReference(4326)) && candidate.Location.SpatialReference.Equals(new SpatialReference(102100)))
                            graphic.Geometry = _mercator.ToGeographic(graphic.Geometry);
                        else if (MyMap.SpatialReference != new SpatialReference(4326))
                            GeometryService geometryService =
                                new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
                            geometryService.ProjectCompleted += (s, a) =>
                                graphic.Geometry = a.Results[0].Geometry;
                            geometryService.Failed += (s, a) =>
                                MessageBox.Show("Projection error: " + a.Error.Message);
                            geometryService.ProjectAsync(new List<Graphic> { graphic }, MyMap.SpatialReference);
                    _candidateGraphicsLayer.Graphics.Add(graphic);
            if (_candidateGraphicsLayer.Graphics.Count > 0)
                CandidatePanelGrid.Visibility = Visibility.Visible;
                CandidateListBox.SelectedIndex = 0;
        void _candidateListBox_SelectionChanged(object sender, SelectionChangedEventArgs e)
            int index = (sender as ListBox).SelectedIndex;
            if (index >= 0)
                MapPoint candidatePoint = _candidateGraphicsLayer.Graphics[index].Geometry as MapPoint;
                double displaySize = MyMap.MinimumResolution * 30;
                ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(
                    candidatePoint.X - (displaySize / 2),
                    candidatePoint.Y - (displaySize / 2),
                    candidatePoint.X + (displaySize / 2),
                    candidatePoint.Y + (displaySize / 2));
                MyMap.ZoomTo(displayExtent);
        private void LocatorTask_Failed(object sender, TaskFailedEventArgs e)
            MessageBox.Show("Locator service failed: " + e.Error);
        private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args)
            FeatureLayer featureLayer = sender as FeatureLayer;
            for (int i = 0; i < featureLayer.SelectionCount; i++)
                featureLayer.SelectedGraphics.ToList().UnSelect();
            args.Graphic.Select();
            MyFeatureDataForm.GraphicSource = args.Graphic;
            FeatureDataFormBorder.Visibility = Visibility.Visible;
        private void EditorWidget_Loaded(object sender, RoutedEventArgs e)
            string[] myLayerIDs = { "PointLayer" };
            MyEditorWidget.LayerIDs = myLayerIDs;
MattMiley
Still having trouble with this, its really weird, it won't let me add and save attributes unless i refresh the page and click or change other features first.
JenniferNery
You can do the following:
* set Geometry with LocatorTask result.
* set Attributes with default value, you might need to check FieldType, Editable, Nullable, etc.
* add to FeatureLayer before using FeatureDataForm/FeatureDataGrid
var g = new Graphic();
g.Geometry = geocodeResult;
foreach (var f in l.LayerInfo.Fields)
 g.Attributes[f.Name] = null;
l.Graphics.Add(g);
var childWindow = new ChildWindow();
var fdf = new FeatureDataForm() { FeatureLayer = l, GraphicSource = g };
childWindow.Content = fdf;
childWindow.Show();
MattMiley
l.Graphics.Add(g);
childWindow.Show();
Thanks Jennifer
You're the best, everything worked great except for when i hit the okay button on the FeatureDataForm dialog box it won't close. It only closes if you hit the X to close, The added attributes work though so I'm happy.
I was able to add the following code to get the date down to the minute instead of just the day as well..
 g.Attributes["Date"] = DateTime.Now;
g.Attributes["Job_Location"] = InputAddress.Text;
JenniferNery
If you want the OK button to close your window, you can do this:
        var fdf = new FeatureDataForm() { FeatureLayer = layer, GraphicSource = graphic};
        var window = new ChildWindow() { Content = fdf };
        fdf.EditEnded += (a, b) =>
                window.Close();
        window.Show();
MattMiley
How would i auto insert a coded domain
ex     Coded Values: [1: Broken Main], [2: Broken Valve], [3: Broken T Handle]
I tried
 //g.Attributes["Job_Type"] = "2";
 //g.Attributes["Job_Type"] = "'2'";
 //g.Attributes["Job_Type"] = "Broken Valve";
 //g.Attributes["Job_Type"] = "'Broken Valve'";
and it still can't get it to auto populated the drop menu.
JenniferNery
It depends on your service. For example, this service defines its coded value domain as:
STATUS ( type: esriFieldTypeSmallInteger , alias: Status , editable: true , nullable: true ,   Coded Values: [1: New] , [2: Open] , [3: Closed] )
This feature attribute will then be:
graphic.Attributes["STATUS"] = 1;
where datatype is Int16 and is one of the possible code 1, 2, 3.
http://servicesbeta2.esri.com/arcgis/rest/services/SF311/FeatureServer/0/1
MattMiley
Hmm, Still not working, does it matter if that field is used as a Unique Value Renderer?
[HTML]Drawing Info:
    Renderer:
        Unique Value Renderer:
        Field 1: Job_Type
        Field 2:
        Field 3:
        Field Delimiter: ,
        Default Symbol:
            Unsupported Symbol
        Default Label:
        Unique Value Infos:
            Value: 1
            Label: Broken Main
            Description:
            Symbol:
                Picture Marker Symbol:
            Value: 3
            Label: Broken T Handle
            Description:
            Symbol:
            Value: 2
            Label: Broken Valve
            Description:
            Symbol:
            Value: 6
            Label: Dirty Water
            Description:
            Symbol:
            Value: 4
            Label: Hydrant Flush
            Description:
            Symbol:
            Value: 9
            Label: Hydrant Repair
            Description:
            Symbol:
            Value: 10
            Label: Hydrant Replacement
            Description:
            Symbol:
            Value: 5
            Label: Leak
            Description:
            Symbol:
            Value: 11
            Label: New Water Taps
            Description:
            Symbol:
            Value: 7
            Label: Other
            Description:
            Symbol:
            Value: 12
            Label: Replacement Water Service
            Description:
            Symbol:
            Value: 8
            Label: Valve Turn
            Description:
            Symbol:
    Transparency: 0
    Labeling Info: N/A
Has Attachments: False
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Object ID Field: OBJECTID
Global ID Field:
Type ID Field: Job_Type
Fields:
    OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID, Editable: False)
    Job_Type (Type: esriFieldTypeSmallInteger, Alias: Job Type, Editable: True, Domain: Coded Values: [1: Broken Main], [2: Broken Valve], [3: Broken T Handle], ...9 more...)[/HTML]
This didn't work
 g.Attributes["Job_Type"] = 1;
Also the field isn't nullable.
