Identify..?
2708
10
07-27-2010 01:18 PM
JoshV
Hello All-
In the samples on the Resource Center I was able to add the Identify sample to my Silverlight (3.0) App and get it to work.  I now want to add that as a Tool to my Toolbar.  Below is the main section of code in the XAML so does anyone know how I can add it as a ToolbarItem?
Many thanks,
<!-- Identity-->
        <Canvas  HorizontalAlignment="Stretch"  VerticalAlignment="Center" Grid.Row="0" Grid.Column="2">
            <StackPanel Orientation="Vertical" Margin="10" >
                <Grid x:Name="IdentifyGrid" HorizontalAlignment="Stretch"  VerticalAlignment="Center"  Margin="0,7,7,0" >
                    <Rectangle Fill="#22000000" RadiusX="10" RadiusY="10" Margin="0,4,0,0" />
                    <Rectangle Fill="#CC5C90B2" Stroke="Gray"  RadiusX="10" RadiusY="10" Margin="0,0,0,5" />
                    <TextBlock x:Name="DataDisplayTitleTop" Text="Click on map to identify a feature" Foreground="Black" FontSize="10"
                      Margin="10,5,0,0" />
                    <TextBlock x:Name="DataDisplayTitleBottom" Text="Click on map to identify a feature" Foreground="White" FontSize="10"
                      Margin="10,3,0,5" />
                    <StackPanel Orientation="Vertical" Margin="15" HorizontalAlignment="Right" VerticalAlignment="Center">
                        <ComboBox x:Name="IdentifyComboBox" MinWidth="150" SelectionChanged="cb_SelectionChanged"
                         Margin="5,10,5,5" >
                        </ComboBox>
                        <ScrollViewer x:Name="DataGridScrollViewer" HorizontalScrollBarVisibility="Auto" VerticalScrollBarVisibility="Auto"
                         Width="230" MaxHeight="340" Visibility="Collapsed">
                            <slData:DataGrid x:Name="IdentifyDetailsDataGrid" AutoGenerateColumns="False" HeadersVisibility="None"
                              Background="White" >
                                <slData:DataGrid.Columns>
                                    <slData:DataGridTextColumn Binding="{Binding Path=Key}" FontWeight="Bold"/>
                                    <slData:DataGridTextColumn Binding="{Binding Path=Value}"/>
                                </slData:DataGrid.Columns>
                            </slData:DataGrid>
                        </ScrollViewer>
                    </StackPanel>
                </Grid>
            </StackPanel>
        </Canvas>
PreetiMaske
Actually it is pretty simple. All you need to do is add a toolbaritem to toolbar for identify tool.
<esri:ToolbarItem Text="Identify">
                <esri:ToolbarItem.Content>
                  <Image Source="/Assets/images/i_about.png" Stretch="UniformToFill" Margin="5" />
                </esri:ToolbarItem.Content>
              </esri:ToolbarItem>
Create a bool variable and set it true only when "Identify" is clicked.
bool identifyclick;
private void MyToolbar_ToolbarItemClicked(object sender, ESRI.ArcGIS.Client.Toolkit.SelectedToolbarItemArgs e)
case 7: //Identify
          identifyclick = true;
          break;
In Map Mouseclick event check value for this boolean variable to true before running identify logic
private void MyMap_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e)
      if (identifyclick)
        //execute identify code
        identifyclick = false // at the end reset the bool variable to deactivate the identify tool.
Basically it will be combination of ToolbarWidget sample and Identify Sample. Most of the code can be copied from Identify sample and pasted as is to toolbarWidget Sample.
Attached is the sample XAML with implementation. Hope that helps
JoshV
              </esri:ToolbarItem>
bool identifyclick;
case 7: //Identify
          break;
      if (identifyclick)
Hi Preeti-
When I tried to save and open that zip file it said it was corrupt and could not open.  Could you just paste the Identify code needed for taht last part of your post?
Thanks Preeti
PreetiMaske
You can copy the XAML below and make the following additons to the Toolbar sample's codebehind
using System.Collections.Generic;
using System.Windows;
using System.Windows.Controls;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Tasks;
namespace ArcGISSilverlightSDK
  public partial class ToolBarWidget : UserControl
    private List<DataItem> _dataItems = null;
    bool identifyclick = false;
      MyDrawObject.IsEnabled = false;
      _toolMode = "";
      switch (e.Index)
        case 7: //Identify
          break;
      if (identifyclick)
        ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint;
        ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
          Geometry = clickPoint,
          MapExtent = MyMap.Extent,
          Width = (int)MyMap.ActualWidth,
          Height = (int)MyMap.ActualHeight,
          LayerOption = LayerOption.visible
        IdentifyTask identifyTask = new IdentifyTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/" +
            "Demographics/ESRI_Census_USA/MapServer");
        identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
        identifyTask.Failed += IdentifyTask_Failed;
        identifyTask.ExecuteAsync(identifyParams);
        GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
        graphicsLayer.ClearGraphics();
        ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
          Symbol = LayoutRoot.Resources["DefaultPictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
        graphicsLayer.Graphics.Add(graphic);
      if (IdentifyBorder.Visibility == Visibility.Visible)
        IdentifyBorder.Visibility = Visibility.Collapsed;
    public void ShowFeatures(List<IdentifyResult> results)
      _dataItems = new List<DataItem>();
      if (results != null && results.Count > 0)
        IdentifyComboBox.Items.Clear();
        foreach (IdentifyResult result in results)
          Graphic feature = result.Feature;
          string title = result.Value.ToString() + " (" + result.LayerName + ")";
          _dataItems.Add(new DataItem()
            Title = title,
            Data = feature.Attributes
          IdentifyComboBox.Items.Add(title);
        IdentifyComboBox.SelectedIndex = 0;
    void cb_SelectionChanged(object sender, SelectionChangedEventArgs e)
      int index = IdentifyComboBox.SelectedIndex;
      if (index > -1)
        IdentifyDetailsDataGrid.ItemsSource = _dataItems[index].Data;
    private void IdentifyTask_ExecuteCompleted(object sender, IdentifyEventArgs args)
      IdentifyDetailsDataGrid.ItemsSource = null;
      if (args.IdentifyResults != null && args.IdentifyResults.Count > 0)
        IdentifyBorder.Visibility = Visibility.Visible;
        IdentifyResultsPanel.Visibility = Visibility.Visible;
        ShowFeatures(args.IdentifyResults);
      else
        IdentifyComboBox.UpdateLayout();
        IdentifyResultsPanel.Visibility = Visibility.Collapsed;
    public class DataItem
      public string Title { get; set; }
      public IDictionary<string, object> Data { get; set; }
    void IdentifyTask_Failed(object sender, TaskFailedEventArgs e)
      MessageBox.Show("Identify failed. Error: " + e.Error);
    private void DataDisplayTitleBottom_MouseLeftButtonDown(object sender, System.Windows.Input.MouseButtonEventArgs e)
===================== XAML ============================================
<UserControl x:Class="ArcGISSilverlightSDK.ToolBarWidget"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
    xmlns:slData="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Data" >
  <Grid x:Name="LayoutRoot" Background="White">
    <Grid.Resources>
      <esri:SimpleFillSymbol x:Key="DefaultFillSymbol" Fill="#33FF0000" BorderBrush="Red"
                                          BorderThickness="2" />
      <esri:PictureMarkerSymbol x:Key="DefaultPictureSymbol" OffsetX="35" OffsetY="35"
                 Source="/Assets/images/i_about.png" />
    </Grid.Resources>
    <esri:Map x:Name="MyMap" Extent="-33,-12.85,99.75,87.15"
                  ExtentChanged="MyMap_ExtentChanged" MouseClick="MyMap_MouseClick">
      <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
                    Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" />
      <esri:GraphicsLayer ID="MyGraphicsLayer" />
    </esri:Map>
    <Grid Height="110" HorizontalAlignment="Right" VerticalAlignment="Top" Margin="0,10,10,0" >
      <Rectangle Fill="#77919191" RadiusX="10" RadiusY="10" Margin="0,4,0,6" >
        <Rectangle.Effect>
          <DropShadowEffect/>
        </Rectangle.Effect>
      </Rectangle>
      <Rectangle Fill="#CCFFFFFF" Stroke="DarkGray" RadiusX="5" RadiusY="5" Margin="10,10,10,15" />
      <StackPanel Orientation="Vertical">
        <esri:Toolbar x:Name="MyToolbar" MaxItemHeight="80" MaxItemWidth="80"
                    VerticalAlignment="Top" HorizontalAlignment="Center"
                    Loaded="MyToolbar_Loaded"
                    ToolbarItemClicked="MyToolbar_ToolbarItemClicked"
                    ToolbarIndexChanged="MyToolbar_ToolbarIndexChanged"
                    Width="450" Height="80">
          <esri:Toolbar.Items>
            <esri:ToolbarItemCollection>
              </esri:ToolbarItem>
            </esri:ToolbarItemCollection>
          </esri:Toolbar.Items>
        </esri:Toolbar>
        <TextBlock x:Name="StatusTextBlock" Text="" FontWeight="Bold" HorizontalAlignment="Center"/>
      </StackPanel>
    </Grid>
    <Border x:Name="IdentifyBorder" Background="#77919191" BorderThickness="1" CornerRadius="5"
                HorizontalAlignment="Right" BorderBrush="Gray" VerticalAlignment="Top"
                Margin="5">
      <Border.Effect>
        <DropShadowEffect/>
      </Border.Effect>
      <Grid x:Name="IdentifyGrid" HorizontalAlignment="Right" VerticalAlignment="Top" >
        <Grid.RowDefinitions>
          <RowDefinition Height="30" />
          <RowDefinition Height="*" />
        </Grid.RowDefinitions>
        <TextBlock x:Name="DataDisplayTitleBottom" Text="Close"
                       Foreground="White" FontSize="10" Margin="206,4,6,2" HorizontalAlignment="Center" MouseLeftButtonDown="DataDisplayTitleBottom_MouseLeftButtonDown" >
                    <TextBlock.Effect>
                        <DropShadowEffect />
                    </TextBlock.Effect>
        </TextBlock>
        <Grid x:Name="IdentifyResultsPanel" Margin="5,1,5,5" HorizontalAlignment="Center"
                            VerticalAlignment="Top" Visibility="Collapsed" Grid.Row="1">
                         Margin="5,1,5,5" Grid.Row="0" >
          </ComboBox>
          <ScrollViewer HorizontalScrollBarVisibility="Hidden" VerticalScrollBarVisibility="Auto"
                         Width="230" MinHeight="200" Grid.Row="1">
                              Background="White">
            </slData:DataGrid>
          </ScrollViewer>
        </Grid>
      </Grid>
    </Border>
  </Grid>
</UserControl>
JoshV
Hi Preeti-
I took your suggestions and copied your C# and your XAML and it is nearly exactly the same now in my App.  The only difference is that I use a DynamicMapServiceLayer so in the MyMap_MouseClick event I changed the URL to piont to my local map service.  Everything else looks nearly the same to me but when I run my application and select the Identify button, it acts like it's active but when I select any layers in my dynamic service (wells) it never does anything.
Thoughts?
PreetiMaske
I think the spatialReference for the Wells layers is different than the basemap layer. The Extent that is going as parameter to identifytask is using the basemap's extent which probably does not match with coordinate system of the Wells layer and that is causing the identifyTask to not return any results. You can put a breakpoint in MyMap_MouseClick to see what is the extent passed to Identifytask parameters and also in IdentifyTask_ExecuteCompleted to see if any results are returned.
--Preeti
JoshV
--Preeti
I thought the same thing but when I changed the MouseClick's Identify task to http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer  and then I declared my DynamicMapServiceLayer to be that as well, when I debugged the application it still did not work.  Shouldn't that URL be the same as the maps?  Could I change the WKID of the map to be what my DynamicService is?
PreetiMaske
It works fine for me...Can you send the code?
JoshV
Here is my code using the ESRI Rest URL's instead of my dynamicmapservice.  Thanks for taking a look at it..
(I included all of it so its attached)  The XAML is split into 2 files and the CS is in 2 files.  the size limitations..geez
PreetiMaske
You haven't added the handler for MouseClick for map in your XAML.
<esri:Map x:Name="MyMap" MouseMove="MyMap_MouseMove" Extent="-120, 30, -60, 60" MouseClick="MyMap_MouseClick" >
<esri:Map.Layers>
<esri:ArcGISTiledMapServiceLayer ID="AGOLayer"
Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_ShadedRelief_World_2D/MapServer"/>
<esri:ArcGISDynamicMapServiceLayer ID="DynamicLayerCalifornia"
Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer"
InitializationFailed="Layer_InitializationFailed" />
</esri:Map.Layers>
</esri:Map>
</esri:Map.Layers>
</esri:Map>
