Identify problem
11861
35
04-25-2011 11:43 AM
DanielSchatt
I'm trying to use the identify functionality that is in the Identify sample. I have set
LayerOption = LayerOption.Visible
just as in the sample.  I assumed this means that all layers are accessible by the identify tool, but only layers that are checked as visible in the web application at any given time will be identified.  That's what I want.
But what's happening is that the identify function is only working on the layers that I set as visible in the original .mxd (and which therefore show initially as visible when I load the web site).  Those layers will always be identified in the web application whether they are visible or not, and other layers will never be identified whether they are visible or not.
Is this what's supposed to happen?  How can I get it to behave as I want? Thanks so much for any help...
BarraLoubna
j'ai fait ça:
            FeatureLayer dynamicServiceLayer = (FeatureLayer)MyMap.Layers["Limites_Administratives"];
            ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint;
            ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
                Geometry = clickPoint,
                MapExtent = MyMap.Extent,
                Width = (int)MyMap.ActualWidth,
                Height = (int)MyMap.ActualHeight,
                LayerOption = LayerOption.visible,
                SpatialReference = MyMap.SpatialReference,
            IdentifyTask identifyTask = new IdentifyTask    ("http://romulus/ArcGIS/rest/services/Limites_Administratives_Luxembourg/MapServer");
            identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
            identifyTask.Failed += IdentifyTask_Failed;
            identifyTask.ExecuteAsync(identifyParams);
            GraphicsLayer graphicsLayer = MyMap.Layers["Limites_Administratives"] as GraphicsLayer;
   ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
                Symbol = LayoutRoot.Resources["DefaultPictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
            graphicsLayer.Graphics.Add(graphic);
But there are no results, the table of Identify is empty.
Someone have another idea? please help me.
JannalynPontello
After the identify parameters, you need to add back this, too. This is what adds the layers to the identify task.
if (dynamicServiceLayer.VisibleLayers != null)
foreach (int x in dynamicServiceLayer.VisibleLayers)
identifyParams.LayerIds.Add(x);
if (dynamicServiceLayer.VisibleLayers.Length == 0) return;
BarraLoubna
I had already tested and does not work 😞
it gives me this error :
ESRI.ArcGIS.Client.FeatureLayer does not contain a definition for 'VisibleLayers' and no extension method 'VisibleLayers' accepting a first argument of type 'ESRI.ArcGIS.Client.FeatureLayer' could be found (are you missing a using directive or an assembly reference?)
JannalynPontello
I'm not sure, but I think the feature layer is causing the problem. Could you test by using an ArcGISDynamicMapServiceLayer in your xaml and then identifying using that layer?
BarraLoubna
It does not work also 😞
It no longer gives the error before, but the Identify table does not contains anything.
BarraLoubna
Is does anyone has another idea?
Where is the ESRI teams? please help-me.
