How to setup an ElementName property for a binding from a different xaml file?
990
08-23-2011 07:45 AM
weiliang
I try to use the esri:Editor and put it into a separate file (e.g., editor.xaml) from MainPage.xaml. However, there is a Map property for this esri.Editor that I need to setup the binding. If this esri:Editor is in MainPage.xaml, the code should be
<Grid.Resources>
            <esri:Editor x:Key="MyEditor2" x:Name="EditPolygon" Map="{Binding ElementName=MyMap}"  LayerIDs="Polygon" GeometryServiceUrl="" />
</Grid.Resources>
Could someone tell me how to bind this MyMap element from MainPage.xaml to the Map property in the editor.xaml?
Wei
JenniferNery
I think this could be a related thread: http://forums.arcgis.com/threads/15944-How-to-binding-mainpage-s-map. In this case, Element binding need to be replaced. Kindly see attached sample in Post#12.
