How to get legend information using a REST endpoint and what to do with it
1279
06-06-2011 02:48 PM
BranonBarrett
I have an issue where I am adding layers to a map service dynamically and I need to keep the legend information in sync; however, after I add the layer to the map service/refresh the REST cache/then set the visible layers on the service on the client side the legend information (i.e. the images) are not refreshed. I tried simply calling the Legend.Refresh method, but that does not force the server to send a new image. Once the ArcGISDynamicMapServiceLayer has been initialized (and any subsequent initialize call) does not return a new legend information.
Is there any way to set the Image source for a legend item using a REST endpoint (ex. http://localhost/ArcGIS/rest/services/UserLayers/MapServer/Legend/0?f=json&pretty=true)?
Am I stuck building a custom legend control for this seemingly straight forward issue?
Any ideas would be greatly appreciated.
DominiqueBroux
Esri Frequent Contributor
Did you try to set DisableClientCaching to true for your ArcGISDynamicMapServiceLayer ?
BranonBarrett
I did, and that did not work. It appears that property only refers to caching the map images? Any other ideas?
DominiqueBroux
Oops, you are right the legend infos are cached at the client side once the first query has been done.
I guess it's a bug we need to fix in a future version.
I'll try to find a workaround and let you know:confused: (at least the creation of a new layer should work. OK it's awful, I agree)
