How to get Layer Description
1414
03-15-2011 10:42 PM
LakshmananVenkatesan
Hi
I have a dynamic map service with 60+ layers. For each layer I have added specific description. I want to get the description for each layer using Sliver light API. How to get the description.?
I can see the description text in my rest services.
Layer description is always null
API help says LayerLegendInfo has LayerDescription property which provides description of the layer. But  I do not know how to access layer Legend info class and get the layer description property
Pl help
SR
JenniferNery
You can include a LegendExtension from this thread: http://forums.arcgis.com/threads/18999-How-do-I-get-the-selected-LegendItem and access the selected LegendItemViewModel.
private void Button_Click(object sender, System.Windows.RoutedEventArgs e)
 var result = this.MyLegend.SelectedItems();
 foreach (var item in result)
  MessageBox.Show(item.Description);
Another way is to parse the json.
private void ArcGISDynamicMapServiceLayer_Initialized(object sender, System.EventArgs e)
 ArcGISDynamicMapServiceLayer layer = sender as ArcGISDynamicMapServiceLayer;
 foreach (var l in layer.Layers)
  //TODO use this sub layer url
  //string.Format("{0}/{1}/f=json", layer.Url, l.ID));
http://forums.silverlight.net/forums/p/169016/385411.aspx
OrenGal
Just needed to read Description from my 188 layers in the MXD. Used soap.
System.ServiceModel.EndpointAddress endPointAddress = new System.ServiceModel.EndpointAddress(pURL);
                System.ServiceModel.BasicHttpBinding basicHttpBinding = new System.ServiceModel.BasicHttpBinding() { MaxReceivedMessageSize = 2147483647 };
_client = new MapServerPortClient(basicHttpBinding, endPointAddress);
_client.GetServerInfoCompleted += new EventHandler<GetServerInfoCompletedEventArgs>(_client_GetServerInfoCompleted);
_client.GetServerInfoAsync("Layers");
private void _client_GetServerInfoCompleted(object sender, GetServerInfoCompletedEventArgs e)
    e.Result.MapLayerInfos....
Oren.
http://www.gal-systems.com
JenniferNery
Thank you for sharing your code. We have also included GetDetails() and GetAllDetails() in v2.3 to give you metadata information about a specific layer or all sub layers of ArcGISDynamicMapServiceLayer or ArcGISTiledMapServiceLayer.
OrenGal
Great!
(What is v2.3? I'm using 3.0 beta1)
