How to create a new feature doing a copy/paste from another feature?
628
07-24-2012 12:00 PM
JoseSanchez
Hi all
In silverling how can I create a new polygon feature copy/pasting one or several existing properties (polygons).
The goal is to allow an end user to creaet a new project selecting an area covered by one or several properties.
In ArcMap it is really easy, but how can I do that with silverlight?
JenniferNery
You would need to create another Graphic that clones original Graphic's geometry and copies original Graphic's Attributes.
For example, you can subscribe to the source layer's MouseLeftButtonDown
  private void GraphicsLayer_MouseLeftButtonDown(object sender, GraphicMouseButtonEventArgs e)
   var l = MyMap.Layers["DestinationLayer"] as GraphicsLayer;
                        // This code clones the geometry (i.e. Polygon)
   var g = new Graphic() { Geometry = Geometry.Clone(e.Graphic.Geometry) };
                       // This code clones the attributes.
   foreach (var item in g.Attributes)
    g.Attributes[item.Key] = item.Value;
   l.Graphics.Add(g);
