How to Collapse magnifyingGlass
799
10-07-2010 04:45 AM
ShaningYu
Honored Contributor
Scenario Desription:
1) Created MagifyingGlass.xaml and loaded ESRI's sample code in http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MagnifyingGlass
2) Created a button on the toolbar for the MagnifyingGlass tool
   if (btn == btnMagnifyingGlass) {
         // if it is collapsed
         _Parent.ShowMagnifyingGlass();
   and
        public void ShowMagnifyingGlass()  {
            MyMagnifyingGlass.Visibility = Visibility.Visible;
Questions:
1) How to check whether the tool is collapsed or not (can't do like that: MyMagnifyingGlass.Visibility.Collapsed )?
2) How to set the tool Collapsed or Visible?
Thanks.
JenniferNery
The MagnifyingGlass is just like any other Control. It's Visibility can be checked and set just as you would any other Control.
Questions:
if (this.MyMagnifyingGlass.Visibility == System.Windows.Visibility.Collapsed)
   this.MyMagnifyingGlass.Visibility = System.Windows.Visibility.Visible;
ShaningYu
Honored Contributor
Thanks!  Jenniffer.  You are very helpful!!!
