How to add one more image button in EditorWiget?
1176
10-26-2010 12:48 PM
XiujuZhou
I need to add one more button in EditorWiget for some operation. Is it possible to customize it by adding the button? Hope get help from expertise here. Thanks
JenniferNery
Sure. Please look at this related thread:http://forums.arcgis.com/threads/14328-Extending-Editor-Widget
XiujuZhou
Jeniffer, I just need graphically add a image button into EditorWidget toolbar like in Expression Blend. How to that?  the link you gave me is only for functional code behind. I don't need those since I have already.
JenniferNery
It is actually similar in Expression Blend.  You will still need to edit the template and create a style.  You then modify the style by drag/drop (if you prefer) or update the xaml.
http://msdn.microsoft.com/en-us/library/cc294908(v=Expression.40).aspx
AgatinoLa_Rosa
I have Expression Blind, AGS 10 sp 1 and trying to organize horizontally the symbols of the Feature Layers - not stacked vertically - to be edited in a SL web app. I have seen the link
however I am not able to customize the editor template I cannot see 'Edit Template'. Any help?
