How Publish Dynamic Layer Map having Relationship
1014
05-31-2011 12:13 AM
MuhammadWaqar_ul_islam
I want to Published Dynamic Layer having Relationship with table with in gdb (snapshot is attached of the mxd showing relation)
when i try to published mxd through arccatalog
and clicking on checkbox Mapping,Featureaccess,KML
it gives error
Configuration SSGC_RELATION.MAPSERVER can not be started
Server object instance creation failed on machine
I m using http://help.arcgis.com/en/webapi/silverlight/2.2/samples/start.htm#QueryRelatedRecords
sample
need help
To Published Relationship Services using arcgis server 10
SanajyJadhav
To enable feature access, your data must come from ArcSDE.From the attached screenshot, it seems that you are pulling data from your D drive and thats why I guess, you are getting an error.
Try publishing data that comes from ArcSDE and then try.
