How do you set a default size of a control that you can resize?
1157
01-06-2012 04:09 PM
wmthompson
I have been looking at a code sample from Charles Petzold.
It is from here:
http://www.charlespetzold.com/blog/2009/05/Realizing-a-Fisheye-Effect-in-Silverlight.html
it uses mouse over methods to increase the size of button classes.
I have it working but I want to make some modifications.  I want the starting size of the button to be larger.  I do not know how much of the code I need to post here to make the issue clear enough.  The XAML for the page describes a "FisheyeButton" that is described in a seperate xaml file.  Something like this:
<StackPanel x:Name="LayoutRoot" Width="1017" Orientation="Horizontal" Height="253">
    <src:FisheyeButton Style="{StaticResource btnStyle}" ButtonContent="Button No. 1" />
</StackPanel>
The functionality of the project is such that if I give the Fisheyebutton a width and height a set size at this loction, the effect where the size of the control the effect of becoming larger does not happen.  In other words, if I write in the <src:FisheyeButton... tag above Width="100", then the button does not behave at run time as it should.
In the same page.xaml file, the btnStyle is defined like this:
<UserControl.Resources >
   <Style x:Key="btnStyle" TargetType="src:FisheyeButton">
      <Setter Property="VerticalAlignment" Value ="Center" />
      <Setter Property="HorizontalAlignment" Value ="Center" />
      <Setter Property="FontSize" Value ="12" />
   </Style >
</UserControl.Resources >
I wonder if perhaps at this point, I can add a "Setter" property to define a default starting widh and height for the class.
The animation, what makes the custom button class grow larger and also return to a normal size, is done in a seperate XAML for the Fisheyebutton class:
<UserControl x:Class="FisheyeButtons6.FisheyeButton"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:vsm="clr-namespace:System.Windows;assembly=System.Windows"
             xmlns:src="clr-namespace:FisheyeButtons6"
             mc:Ignorable="d"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             d:DesignHeight="64" d:DesignWidth="146">
    <Grid x:Name="LayoutRoot" Background="White" >
        <vsm:VisualStateManager.VisualStateGroups>
            <vsm:VisualStateGroup x:Name="CommonStates">
                <vsm:VisualState x:Name="Normal">
                    <Storyboard>
                        <DoubleAnimation Storyboard.TargetName="presenter"
                                         Storyboard.TargetProperty="ScaleX"
                                         To="1" Duration="0:0:0.25" />
                                         Storyboard.TargetProperty="ScaleY"
                    </Storyboard>
                </vsm:VisualState>
                <vsm:VisualState x:Name="MouseOver">
                    <Storyboard>
                                         To="3" Duration="0:0:1" />
                    </Storyboard>
                </vsm:VisualState>
            </vsm:VisualStateGroup>
        </vsm:VisualStateManager.VisualStateGroups>
        <Button>
            <src:ScalableContentPresenter x:Name="presenter" />
        </Button>
    </Grid>
</UserControl>
DominiqueBroux
Esri Frequent Contributor
That question doesn't seem related to the ArcGIS API, may be best answered at a Silverlight forum http://forums.silverlight.net/.
