Hide visibility of one table in ArcGISDynamicMapServiceLayer
2133
08-10-2014 11:49 PM
JulieBiju
Dear All,
I need urgent help
<esri:ArcGISDynamicMapServiceLayer ID="StreetMapLayer" Url="http://www.site.com/arcgis/rest/services/Ss/map1/MapServer"/>
In my web application map is showing properly . In StreetMapLayer I have 10 tables named (nametab,countrytab,sertab, etc....). Now I can see all these 10 layers when I run the application.
Now my requirement is , we dont want to give permission to one user to see 2 layeres from these 10 layers.How can I hide countrytab,sertab from code behind?
Pls help me
AsserSwelam1
Hi Julie,
Sure you can.
using the VisibleLayers property for the DynamicMapServiceLayer.
lets say your user names notAllowedUser and your countrytab is the second layer on the map with index 1 and sertab is tenth layer on the map with index 9.
you will create a int array contain all layer indexes except this two like below and set it to the DynamicLayer.
if( notAllowedUser is the logged user)
     int[] myVisibleLayers = {0, 2, 3, 4, 5, 6, 7, 8};
     myArcGISDynamicMapServiceLayer.VisibleLayers = myVisibleLayers;
else
     int[] myVisibleLayers = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9};
That will help too too
ArcGIS API for Silverlight API Reference| ArcGIS for Developers
Hope that helps.
Asser
