Group layer: sub-layer visibility
1728
04-23-2010 11:59 AM
JamesMolohon
I'm trying to set the visibility of a sub layer of an ArcGISDynamicMapServiceLayer by removing the index of the layer from the VisibleLayers array.  I'm able to get this to work for layers that are not part of a group.  Is this possible?  Can anyone share an example?
Regards,
James
JamesMolohon
For example, I have a dynamic map service that has layers like this:
Layers:
  • Background (0)
    • Roads Overview (1)
    • Airport (2)
    • Parks (3)
  • Buildings (4)
  • Roads (5)
I would like to hide the Airport layer, so I removed 2 from the VisibleLayers array, but it is still visible.
DominiqueBroux
Esri Frequent Contributor
It should work the same way when a sublayer is part of a group.
Look with Fiddler or Firebug what the url to get the image is. You should see a layers parameter with the list of visible layers.
/Dominique
BedaKuster
The REST interface uses an other "Visibility Management" as the SOAP Interface.
If you set the Visibility of a grouplayer to visibile (add the id to the list) all sublayers will be visible. To hide one sublayer, remove the grouplayer id and add each visible sublayer id.
Background (0)
[INDENT]VisibleLayer(1)[/INDENT]
[INDENT]VisibleLayer(2)[/INDENT]
[INDENT]InvisibleLayer(3)[/INDENT]
If id 0 is in the VisibleLayers array, all sublayers are visible. So remove id 0 and add 1 and 2.
Hope this helps
DrewDowling
Thanks you this was killing me. I couldn't figure out why sublayers that were not on by default kept appearing when I toggled a group layer. I found no documentation about this and it is different than how ArcMap works.
