Graphic.Attributes - can I make keys case insensitive?
867
01-20-2011 11:03 AM
KirkKuykendall
I've got several featurelayers with a foreign key column, some have Fk_Proj_ID, some with FK_PROJ_ID some with ...
Anyway, is there some way I can force the IDictionary<string,object> to use a case insensitive comparator?
dotMorten_esri
Esri Notable Contributor
No. Keys are case sensitive by design.
Ensure that your services are all using the same casing prior to publishing the service.
