Get the current zoom level and Lat/Long
8434
01-03-2012 04:34 PM
TylerRothermund
How can I get the current zoom level and center point Lat/Long of the map?  I need to save these settings so I can restore them the next time the user hits the page.
SanajyJadhav
Can you clarify "current zoom level"?
If you mean current extent, you can get it by Map.Extent and it's center as Map.Extent.GetCenter().
TylerRothermund
Is MyMap.Extent.GetCenter().X , Y  = Lat / Long or are those some kind of screen coordinate?
Is there a property that tells me how far the user has zoomed (level) into the map like  a (1-9) or something?
JenniferNery
You can look at the following SDK samples:
Map.Extent updates on pan/zoom
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MapExtent
Screen point can be converted to map coordinates
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MouseCoords
You can compare Map.Resolution property against ArcGISTiledMapServiceLayer.TileInfo.Lods.Resolution to know what level you are currently zoomed in.
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ShowMapProperties
TylerRothermund
Shouldn't Map.Resolution = one of the LODs ?
I'm using this map:
http://services.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer
But Map.Resolution doesn't match any of the LODs.
  private int GetZoomLevel()
            double currentRes = MyMap.Resolution;
            var lods = ((ArcGISTiledMapServiceLayer)MyMap.Layers[0]).TileInfo.Lods.ToList();
            int level = lods.IndexOf(lods.Where(l => l.Resolution == currentRes).FirstOrDefault());
            return level;
dotMorten_esri
Esri Notable Contributor
Unless you set SnapToLevels=true on the map, you can zoom between levels, so no there is no guarantee.
You can instead pick the closest one which should be the one currently rendering.
Scale and/or Resolution is the most precise way for determining the zoom since this is a fully linear range as opposed to zoom levels.
