From 10 Tiled MapService to 10.1 Tiled Image Service
2381
07-03-2013 10:40 AM
JasonKuhlman
I am moving from a tiled map to image service in a silverlight app built on Version 2.2..
It is erroring out on Service Initialization. I would like to get this moved before working through rebuilding it based on version 3.1
I have tried this both as ArcGISImageServiceLayer and ArcGISTiledMapServiceLayer.
I am wondiering if the client dll can't handle the new json output?
Any ideas?
Her is what's being thrown
ESRI.ArcGIS.Client.Services.MapServiceInfo. Input string was not in a correct format. ---> System.FormatException: Input string was not in a correct format.
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
   at System.String.System.IConvertible.ToInt32(IFormatProvider provider)
   at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
   at System.Runtime.Serialization.Json.DataContractJsonSerializer.ConvertObjectToPrimitiveDataContract(DataContract contract, Object value, XmlObjectSerializerReadContextComplexJson context)
   at System.Runtime.Serialization.Json.DataContractJsonSerializer.ConvertObjectToDataContract(DataContract contract, Object value, XmlObjectSerializerReadContextComplexJson context)
   at System.Runtime.Serialization.Json.ObjectToDataContractConverter.ReadClassDataContractMembers(DataContractJsonSerializer serializer, ClassDataContract dataContract, Dictionary`2 deserialzedValue, Object newInstance, XmlObjectSerializerReadContextComplexJson context)
   at System.Runtime.Serialization.Json.ObjectToDataContractConverter.ConvertDictionaryToClassDataContract(DataContractJsonSerializer serializer, ClassDataContract dataContract, Dictionary`2 deserialzedValue, XmlObjectSerializerReadContextComplexJson context)
   at System.Runtime.Serialization.Json.DataContractJsonSerializer.ReadObject(Stream stream)
   --- End of inner exception stack trace ---
   at ESRI.ArcGIS.Client.Services.MapService.GetMapServiceInfo(String json)}
