FeatureDataGrid NameSpace
916
02-01-2011 08:37 AM
KeithAnderson
In order to get the FeatureDataGrid example to work on my client I had to add in the Following name space to the top of the xaml:
  xmlns:esriToolkitPrimitives="clr-namespace:ESRI.ArcGIS.Client.Toolkit.Primitives;assembly=ESRI.ArcGIS.Client.Toolkit">
After building it worked.
I took it out and re built and still worked.
Anyone know why that example would not work straight out?
Keith
JenniferNery
Are you talking about this sample? http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureDataGrid
I don't see why adding xmlns:esriPrimitives worked when this specific example does not use it.
I do know that you may need to add project reference to System.Windows.Controls.Data.Input.dll if you simply copied the code to a new Silverlight application.
KeithAnderson
Thank you Jennifer.
I will try to recreate the issue again on a straight copy into a new SL app.
Keith
