FeatureDataGrid and SL API v2.0?
1331
04-19-2010 03:57 PM
MarkDeaton
Esri Alum
I am having problems using the FeatureDataGrid with the Silverlight API 2.0 beta and Silverlight 3. I bind the grid to a graphics layer; once the layer is populated, the text at the bottom of the control shows the correct number of features, but nothing (not even column headers) show up in the body of the control.
I see correct behavior with API 1.2. Is this a known issue?
Thanks.
DeminHu
Hope the following link could help you:
http://forums.esri.com/Thread.asp?c=213&f=2455&t=303154&mc=20
MarkDeaton
Esri Alum
That's good to know about, thanks. In my case, though, the data source is a GraphicsLayer that's not a FeatureLayer, so it unfortunately doesn't support the DisableClientCaching method.
dotMorten_esri
Esri Notable Contributor
This is a known issue and is fixed in the upcoming beta2.
