Export WebMap using PrintTask Failing
2928
04-17-2013 01:58 PM
JohannBorg1
I am using a custom tool to export a webmap to PDF. The tool works successfully through ArcGIS 10.1. The problem crops up when consuming the tool through my Silverlight application using PrintTask. The tool works in an intermittent fashion i.e. sometimes it works, and sometimes it gives an error.
I turned to ArcGIS Manager log and extracted the following error:
Traceback (most recent call last): File "C:\arcgisserver\directories\arcgissystem\arcgisinput\Toolbox\ExportPDSitePlanPart.GPServer\extracted\v101\printingtoolbox\ExportPDSitePlan.py", line 48, in  result = arcpy.mapping.ConvertWebMapToMapDocument(Web_Map_as_JSON, templateMxd) File "c:\program files\arcgis\server\arcpy\arcpy\mapping.py", line 234, in ConvertWebMapToMapDocument return webmap_tuple(*convertArcObjectToPythonObject(arcgisscripting._convertWebMapToMapDocument(webmap_json, template_mxd, notes_gdb, extra_conversion_options))) RuntimeError: Layer "PD Working Layer": Failed to create layer from service at http://10.58.161.70/arcgis/rest/services/DynamicData/WorkingLayerPolygons/FeatureServer/0. Layer "PD Working Layer": Failed to create layer from service at http://10.58.161.70/arcgis/rest/services/DynamicData/WorkingLayerPolygons/FeatureServer/0. Failed to execute (ExportSP). Failed to execute (ExportSP).
I can confirm that I can access the service from the same server where the tool is running. (i.e. 10.58.161.70).
Can someone point me to the right direction?
MayJeff
Do you able to solve this by modify your python script?
