Export To Excel - Null Reference Error
4699
10
08-03-2012 01:30 PM
GreggBreton
I downloaded the following solution file
http://forums.arcgis.com/threads/45538-How-to-make-Export()-is-work-with-ArcGIS-API-for-Silverlight!
Export.zip
QueryWithoutMap.zip
Executed and  queried the default "New" clicked the export button and works fine
Then tried "S", returned records and tried to export and received "Null Reference Exception"
Use the new keyword to create an object instance
Check to determine if the object is null before calling the method
  private static string GetValue(FrameworkElement frameworkElement)
            return frameworkElement is TextBlock ? (frameworkElement as TextBlock).Text : frameworkElement.ToString();
If someone could illustrate how the above would be written to avoid the null exception error
Thank you
GreggBreton
Just changed ID to id and it worked fine
That will do it....Thank you
