ESRI Standard Map Application
2361
09-28-2010 06:26 AM
ShaningYu
Honored Contributor
I used to work on ESRI's Flexviewer and currently work on Silverlight version template ESRIStandardMapApplication.  I followed the procedure in http://help.arcgis.com/en/webapi/silverlight/help/index.html - Working with Templates, and loaded ESRI's ESRI Standard Map Application template as my new project.  Then I received 17 errors.  The 1st error is:
Error 1
Unable to load the metadata for assembly 'ESRIStandardMapApplication1'. This assembly may have been downloaded from the web.  See http://go.microsoft.com/fwlink/?LinkId=179545.  The following error was encountered during load: Could not load file or assembly
'ESRIStandardMapApplication1' or one of its dependencies. The system cannot find the file specified c:\documents and settings\myName\my documents\visual studio 2010\Projects\ESRIStandardMapApplication1\ESRIStandardMapApplication1\MainPage.xaml
I then checked the http://go.microsoft.com/fwlink/?LinkId=179545.  However, I don't know which assembly needs to be unblocked.
If you have experienced this kind of problem, please share your experience.  Thanks.
JenniferNery
ShaningYu
Honored Contributor
Clean Solution and then re-build.  The errors were gone.  Thanks.
