esri:map MouseLeftButtonDown event, stuck mouse cursor
2829
08-10-2010 05:08 PM
StefhanCampos
when i use the event MouseLeftButtonDown stuck mouse cursor and i need click in
another object to enable map click again "without map follow cursor", anybody know how fix these?
ps:I try mouse up event too, this happen with graphics in graphic layer with MouseLeftButtonDown, the graaphic opens a window when window closes, mouse curso  "follow map cursor".
JenniferNery
Which version of ArcGIS API for Microsoft Silverlight/WPF are you using? 1.2 or 2.0?
Jennifer
StefhanCampos
I have two projects with same problem....API's 1.2 and 2.0
HaifengHuang
I have the same question, when popup a child window by MouseLeftButtonDown in a FeatureLayer and then close the child window, the esri map track with the mouse.
dotMorten_esri
Esri Notable Contributor
Make sure you set e.Handled = true in the event handler to prevent the map from getting the event, or use the MouseUp event instead.
ErnestDunwoody
And just how do you do these actions? Would be  a bit more helpful if it was explained in English. What in the world is an event handler and where is it??
