ESRI LOGO
1681
09-27-2010 11:30 AM
DavidAshton
When working with the templates, how do I change out the ESRI logo with my own (logo in the lower right corner of the app.)?
Thanks
David
dotMorten_esri
Esri Notable Contributor
Set IsLogoVisible = false, and place your own element there.
You might want to read the terms of use first though. There are some cases where having the ESRI (and Bing logo) visible is required.
PaulLeedham
Thanks
David
1. Set IsLogoVisible = "False"
2. Add your own image by using a PNG and positioning the image as follows:
<Image HorizontalAlignment="Right" VerticalAlignment="Bottom" Margin="0,0,8,8" Source="PATH TO IMAGE" Width="IMAGE WIDTH" Height="IMAGE HEIGHT" ></Image>
ShaningYu
Honored Contributor
Paul:
I searched through the MainPage.xmal but could not find  IsLogoVisible.
Besides, I could not locate the place for
Wish you can kindly respond my question.  Thanks.
PaulLeedham
Here is some simple XAML code that will hide the logo and add your own image in the bottom right corner of the map:
<UserControl x:Class="ArcGISSilverlightSDK.Map"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid x:Name="LayoutRoot" >
        <esri:Map x:Name="MyMap" IsLogoVisible="False">
            <esri:ArcGISTiledMapServiceLayer ID="MyLayer"
                Url="http://services.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" />
        </esri:Map>
<Image HorizontalAlignment="Right" VerticalAlignment="Bottom" Margin="0,0,8,8" Source="PATH TO IMAGE" Stretch="None"></Image>
    </Grid>
</UserControl>
ShaningYu
Honored Contributor
Paul:
Thanks so much.  It works now.
Shaning
