Error on Building 2.3 Interactive SDK sample
1122
01-13-2012 04:58 AM
MuhammadWaqar_ul_islam
I have download version 3 sample and installed 2.3 api
While building the application its gives error on App.xaml.cs
  private void Application_Startup(object sender, StartupEventArgs e)
            string xmlConfig = e.InitParams["xml"]; "Key Not found exception not handled by user code" The given key was  not present in the dictionary             //this.RootVisual = new Page(xmlConfig);
            this.RootVisual = new LightPage(xmlConfig);
            System.Windows.Browser.HtmlPage.RegisterScriptableObject("mySLapp", this.RootVisual);
i have attached a snap shot of this error
please figure  it out what is the problem or what  i m missing
i have version 2.2 which is working fine dont know what's the problem in the version 2.3
DominiqueBroux
Esri Frequent Contributor
You have to set the Web project as Startup project.
You might also have to set 'Default.htm' as Start Page.
