Editor Widget without Template Picker
1118
09-28-2011 05:44 AM
rbae
Hopefully this is a simple question: is there any way that I can display the Editor Widget without the template picker?
-Ryan
DominiqueBroux
Esri Frequent Contributor
You can restyle the editor widget and remove the template picker.
With Blend : right click the control -> Edit Template -> Edit a copy.
More infos.
rbae
Exactly what I was hoping for.  Thanks Dominique!
JenniferNery
Sure. You can customize the style for EditorWidget by following these steps: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/05/20/Use-control-templates-to-customize.... Collapse the TemplatePicker.
