Editor Widget (how do I limit records in the data grid?)
3127
12
11-16-2011 08:41 AM
JerryBiedenbender
I was wondering if there was a way to limit the records that show up in the data grid. Right now everything in the layer shows up in the grid. Is it possible to not show a record in the grid that has a status as "complete" in one of the fields. Or only populate the data grid by a date range, (only records that have a date no older than a week or something?)
Jerry
MichaelKohler
If all you want to see are the features that are not completed, set the Where clause in the XAML definition of your FeatureLayer....
<esri:FeatureLayer ID="Dispatch" Where="status <> complete"/>
Something like that will "filter" your data. You could also do this in code behind somewhere.
JerryBiedenbender
This seems like what I'm looking for but the code is not quite working. I get an error message when I use the (<>) code. If I take that out and try something else the feature layer does not display anything. Is there another way of writing the code?
Jerry
JerryBiedenbender
I figured it out. I ended up using...
FeatureLayer siteLayer = MyMap.Layers["Dispatch"] as FeatureLayer;
            siteLayer.Where = "Status <> '4'";
            siteLayer.Update();
