Editor Widget Confirm Delete
2492
02-03-2011 11:27 AM
DarellStoick
I'm using the Silverlight Editor widget similar to the sample at [HTML]http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsExplicitSave[/HTML] and would like to add a confirmation before delete.
How would you go about that using this format
<Button x:Name="DeleteButton" Margin="2"
      Command="{Binding DeleteSelected}">
     <TextBlock>Delete<LineBreak/>Selected</TextBlock>
</Button>
Is there a way to call the DeleteSelected from codebehind using the ESRI.ArcGis.Client.Editor Class
in the button click event
Thanks
JenniferNery
Sure. Instead of setting Command property on the Button, you can add a Click event handler that will call DeleteSelected command.
private void DeleteButton_Click(object sender, RoutedEventArgs e)
 var result = MessageBox.Show("Confirm delete?", "Delete", MessageBoxButton.OKCancel);
 Editor editor = LayoutRoot.Resources["MyEditor"] as Editor;
 if (result == MessageBoxResult.OK)
  if (editor.DeleteSelected.CanExecute(null))
   editor.DeleteSelected.Execute(null);
DarellStoick
Works great, Thanks
