Edit Geometry of Editor Widget not updating the geometry
1424
03-23-2011 05:45 AM
roufbaba
I am not able to edit an existing geometry using Edit Geometry tool of editor widget. This can be tested in the sample gallery also.
Need immediate positive response from ESRI support.
Rouf
JenniferNery
Can you link us to the sample that has this issue? Please let us know the steps to reproduce the problem.
My guess is that you see the geometry revert back to its original shape because the EditVertices command gets cancelled when you activate another command.
This might be related thread:
http://forums.arcgis.com/threads/26034-Unable-to-save-edits-to-graphics-on-GraphicsLayer-using-Edito...
roufbaba
Thanks Jennifer,
Yes, I got it now. We either need to click on the same feature again or any other Map area to save the action. But as far as Api's 2.0 is concerned this was not the case. Action was saved even if one selects any other tool.
Regards
Rouf
SteeveCouture
Is there a way to EditVertices command gets completed without click to the edited geometry?
Is there a workaround to accept the edition when the user click anywhere in the map (instead of click on the edited geometry) ?
Steeve
JenniferNery
Instead of using Editor.EditVertices command, you can use EditGeometry. http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.EditGeomet.... This allows you to StartEdit/CancelEdit/StopEdit in code-behind. Note, however, that you may need to Simplify the resulting geometry. http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Simplify
