Dynamically Loading FeatureDataGrids
1093
01-08-2013 11:46 AM
jonathangamble
I'm new to the Silverlight API and have a question concerning FeatureDataGrids
I have a ComboBox, which is dynamically loaded at runtime with a list of feature layers currently in the map.  I want to have the user select a feature layer from the combobox and have the related attribute data populate in a DataGrid.
Can I use FeatureDataGrids for this - and if so, can anyone point me to an example?  If not - can anyone point me to an example with this logic?
jonathangamble
After a long search I found my answer: Yes, this is possible.
I used this thread to find the solutions: http://forums.arcgis.com/threads/22818-Can-I-change-the-data-binding-for-a-FeatureDataGrid-in-code%E...
Basically, I set my featuredatagrid.graphicslayer to equal the selected featurelayer within the combobox (I should also note that I did not need to set a Map binding for my featuredatagrid).
Also, I had to make sure that the 'AutoGenerateColumns' option was set to true for my featuredatagrid to ensure my columns were displayed for each of the feature layers.
jonathangamble
