Display layer based on Google Fusion Tables
4057
8
09-26-2011 03:15 PM
KirkKuykendall
I've been asked to add a layer to a silverlight map depicting information in a Google Fusion Table, specifically this one: http://www.google.com/fusiontables/DataSource?snapid=S232942v7U3
Does anyone know an easy way to do this?
Are there any plans to provide a new layer type in future versions of the Silverlight API that would let me just config a layer using the url like I would any other mapservice layer?
Kirk
DanielWalton
It's something you can do yourself. Just create a class that inherits GraphicsLayer, and in the overriden Initialize() method place code to download the fusion table exported as a csv file (the URL for your table is http://www.google.com/fusiontables/exporttable?query=select%20*%20from%201236296%20), parse it and create Point graphics features with whatever symbol you want. The 'geometry' column is XML formatted according to the KML <Geometry> spec.
KirkKuykendall
Hey Dan -
Thanks for responding!  This makes sense.
Does anyone know if Esri has exposed a method to convert Kml geometries to Esri geometries?
The KmlLayer must be doing this somewhere behind the scenes.
Kirk
DanielWalton
Look here.
DominiqueBroux
Esri Frequent Contributor
You are right the KML layer is doing that behind the scene but it's not exposed publicly.
You can get the kml sources on codeplex and extract the code converting the geometries (look at Extractxxxx methods called by KmlToFeatureDefinition.CreateFeatureDefinition)
KirkKuykendall
Thanks Dominique ...
It turns out it looks like I can set KmlLayer.Url to this url:
http://www.google.com/fusiontables/exporttable?query=select+col8+from+1236296+&o=kmllink&g=col8
(Found using Fiddler and clicking download to kml from the fusion map page).
Now the only pain is converting to web mercator.
The code for the Kml sample sure will be a lot messier when Esri retires the WGS84 basemaps and replaces with web mercator.
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#KmlLayerSimple
DominiqueBroux
Great idea. Much simpler 🙂
This Mortens's post should help.
KirkKuykendall
Hey Dominique -
I'm aware of that strategy.
I really think 99% of the time anyone using a kmllayer will be wanting to display it in web mercator.  So I think bending the no-projection-on-the-client rule makes sense in this situation.
See more discussion here:
http://forums.arcgis.com/threads/40409-Can-KmlLayer-project-to-Web-Mercator-on-the-fly
DominiqueBroux
OK. I got it.
I guess with your post, this enhancement will move up in the priority list:)
