Define MapTip of Feature Layer
2596
02-11-2013 10:07 AM
EnriqueIbarra
I'm working with a Feature Layer and need to define a MapTip in code behind C#, I'm following the sample http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#FeatureLayerMapTips but still not find the way to declare the MapTip in code behind. Is that possible?'
DominiqueBroux
Esri Frequent Contributor
You can either create your own maptip control and instantiate it by code, or declare the datatemplate in the resources and instantiate a ContentControl by code (see this thread).
DominiqueBroux
EnriqueIbarra
Thanks Dominique!
