DataPager not working when binding to silverlight datagrid with URL ArcGIS service!
1943
12-11-2011 05:20 AM
AnhTruong
Hello,
I searched for paging solution in ArcGIS for Silverlight dataGrid and could not find out the solution???
In my dataPager, I can see how many pages but when I navigate using next, previous the data not display by page size.
Here are my codes as following:
MainPage.xaml
<sdkataPager x:Name="SCHPager" Grid.Column="1" Grid.Row="1" VerticalAlignment="Bottom" Background="#FF333333" Foreground="#FFE5E5E5" BorderBrush="Black" Source ="{Binding Path = ItemsSource, ElementName=QueryDetailsDataGrid}" PageSize="30" />
MainPage.xaml.cs
QueryTask queryTask = new QueryTask("http://egis/ArcGIS/rest/services/SCH/MapServer/0");
queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted;
queryTask.Failed += QueryTask_Failed;
ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query();
query.Text = TaskNumberTextBox.Text;
query.OutFields.Add("*");
query.Where = "1=1";
queryTask.ExecuteAsync(query);
QueryDetailsDataGrid.ItemsSource = new PagedCollectionView("http://egis/ArcGIS/rest/services/SCH/MapServer/0");
SCHPager.Source = QueryDetailsDataGrid.ItemsSource;
Anything extra code in my code behind? I am newbie to ArcGIS API for silverlight, so I really need your expertise to make it happen. Thanks in advance.
JenniferNery
To enable paging in your data grid, you need to use PagedCollectionView. You cannot create an instance of PagedCollectionView by passing service url. You need to pass the results of your Query. http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryWithoutMap.
PagedCollectionView pagedCollectionView;
void QueryTask_ExecuteCompleted(object sender, QueryEventArgs args)
 pagedCollectionView = new PagedCollectionView(args.FeatureSet);
AnhTruong
Here are my detailed code after changes as following:
MainPage.xaml.cs
private void LoadData()
QueryTask queryTask = new QueryTask(URLService);
// How do you make changes for two following lines???
FeatureSet featureSet = args.FeatureSet;
if (featureSet != null && featureSet.Features.Count > 0)
QueryDetailsDataGrid.ItemsSource = featureSet.Features;
else
MessageBox.Show("No features returned from query");
MainPage.xaml
<sdk:DataPager x:Name="SCHPager" Grid.Column="1" Grid.Row="1" Source ="{Binding Path = ItemsSource, ElementName=QueryDetailsDataGrid}" PageSize="30" />
I added new code to QueryTask_ExecuteCompleted(object sender, QueryEventArgs args) but nothing seems to be working at all. Please double check it. Thanks.
DominiqueBroux
Esri Frequent Contributor
else
should be:
QueryDetailsDataGrid.ItemsSource = pagedCollectionView ;
else
AnhTruong
You're super code. Thanks again.
should be:
else
