Customized logo
1030
08-24-2011 07:54 AM
ShaningYu
Honored Contributor
I want to a customized image (logo) at the low-right position to overlay on ESRI's logo.  Does anyone have a piece of code for sharing?  Thanks.
weiliang
To take off the ESRI's default logo, you can simply set the IsLogoVisible attribute in the Map control to False in your xaml file.
Hope this may help,
Wei
ShaningYu
Honored Contributor
Actually, it is set as "False".
<Grid Grid.Row="1" Grid.Column="1">
<!-- Map-->
  <esri:Map x:Name="PrintMap" IsLogoVisible="False"
But ESRI's logo is still at the bottom-right.  Therefore, I plan to use our logo to overlay on it.
DominiqueBroux
Esri Frequent Contributor
Do you mean that even after setting IsLogoVisible to false, the Esri logo is still visible?
If it's the case, it looks like a bug. Could share how to reproduce that?
