Custom Maptip
646
06-11-2010 12:54 AM
linusang
I'm creating a multitouch version. And would like to create custom map tip behavior on the graphic layer. I would like to show 2 or more maptips simultaneously and also add a close button so as to let the user close the map tip when desired.
any guide, suggestions, advice, samples on doing so?
thanks
DominiqueBroux
Esri Frequent Contributor
Morten gave some interesting clues in this discussion : http://forums.arcgis.com/threads/3888-Turning-an-ArcGISDynamicMapServiceLayer-into-a-FeatureLayer
You don't create a MapTip as such. You just instantiate a usercontrol that contains the information you need, add it to the page, and position at the click position (you can use e.GetPosition(parentOfMyCustomMapTopControl) to get that location). Use the margins/alignments on the control to position it.
Hope this help.
