CRUD SDE by Silverlight API
1392
10-25-2011 05:06 AM
bayramüçüncü
I am new about Esri Silverlight Api,
I searched on web for hours but cannot find samples to create, insert, update, delete from silverlight to database. For example I want to draw polyline and save to database. Later delete it.
rbae
There are plenty of samples, forum discussions and documentation on this topic.  Do a search for Feature Service - that is probably a good place to start.
-Ryan
bayramüçüncü
I could not found...
Is there  working sample?
or else where can I learn the modify the table data from silverlight.
Esri might be tell the subject.
RobertBurke
To see live editing sample apps and the supporting code, go to:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm
In the table of contents, expand Editing where you will see 9 edit examples.
I hope this helps,
Rob
Rob Burke
