ChildLayer not visible under the GroupLayer
1323
03-19-2014 08:48 AM
TroyProctor
I'm made an exact copy of the code from the Group Layers sample below and I can't get the ChildLayers to show up. I only end up seeing the "Bloomdfield Hills" parent layer. See attached Screenshot.
I'm not sure what I'm missing.
https://developers.arcgis.com/silverlight/sample-code/start.htm#GroupLayers
Troy Proctor
DominiqueBroux
Esri Frequent Contributor
You might have defined a default legend style in your app that would overwrite the standard legend style.
Look in your app if there is no style defined for the legend (for example in  app.xaml)
DominiqueBroux
TroyProctor
Thank you much Dominque!
I did have a default Legend Style in App.xaml. As soon as I got rid of it, everything worked as expected.
Troy Proctor
