Can I edit the feature dynamically on the website?
1254
05-04-2010 01:06 PM
weiliang
I know in ADF there is such a task that can allow the end user to edit the feature from the map service dynamically on the website. Is there such functionality in Silverlight?
Also, will there a management console for silverlight API similar as ADF in ArcGIS 10?
Many thanks,
Wei
dotMorten_esri
Esri Notable Contributor
Yes. See the editing samples in the 2.0beta SDK:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ToolkitEditorWidget
No.
weiliang
Many thanks! You guys are really helpful.
Wei
DougCollins
OK,
I looked at the editing samples, but it appears that much of the code behind is missing relative to the "save edits" operation.  Or am I just missing something?
Charlie
dotMorten_esri
What do you mean the code behind is missing? In many cases you don't really need to do any code behind to do editing. It's all handled by using the ICommand pattern. Edits are automatically saved, unless you explicitly disable it on the feature layer.
