Cache problem
1016
05-02-2012 10:43 PM
SantoshV
HI,
I have created cache(fusion layers) for my services by right clicking on the mapservice in arc-catalog and clicking create cache
It works fine in my application but the problem is after viewing the cache when do map full extent the cache is still visible when it had to hide since I have set zoom visibility
Please guide me as to how I can keep the map cache visibility off when it is out of the zoom visibility
Regards
Santosh V
JenniferNery
You can set the layer's Minimum and Maximum Resolution. This will change its visibility if Map.Resolution is not within this range.
