Bing Map key : ArcGIS Server 10.1
3683
06-29-2012 01:03 PM
DeminHu
In ArcGIS server 10, if we login manager, go setting,then login with ArcGIS Server admin account, we could retrive bing map code to develop application and add bing layers .
After I set up ArcGIS server 10.1, we could not find a way to retrieve the bing map code, from ArcGIS server 10.1 set up help, I found :
http://resources.arcgis.com/en/help/main/10.1/index.html#//0155000004qm000000
In version 10, I could retrieve my Bing Maps key from Manager. How do I do this in 10.1?
The ability to retrieve your Bing Maps key using Manager has been removed at 10.1. You should visit the Esri Customer Care website or contact your Esri customer service representative to find out your key.
So I called ESRI customer support, I was connected to product specialist, customer service, after a few rounds, I was told: if you need use bing map, you just added from ArcMap. I was asked to send them email about above link, I did, then I got the email from ESRI support again:
What authorization code are you using for the Server product? The Product Specialist is asking. They need this information to assist with your questions below.
Actully I am using ArcGIS Server enterprise, I just wnat to know if I can get a bing map key to develop ArcGIS Server SL application which could add bing layers as background layer , like we did in ArcGIS Server 10.
Anybody knows?
AndrewMilanes
Ever figured this out?  I have the same question.
DeminHu
