Bing - Constrained Extent Behavior bug
938
07-19-2010 09:17 AM
JoshWerts
Has anyone else experienced an issue with zooming on a Bing baselayer with constrained extent behavior applied to the map?  When the map is zoomed in via the mouse wheel quickly, the cpu is maxed out and memory allocated to the browser continually rises with no end (and the browser does not respond of course).
Removing the behavior solved the issue but would like to use it.
Josh
Clemson University
JenniferNery
Is your ZoomDuration set to 0 or some small number? Are you able to replicate this issue with another base layer? If your answer is yes on the first question, we are currently working on this issue.
Jennifer
