bind map from Map Page
4542
02-28-2015 09:18 PM
Asgharkhan
Dear Experts , i want to bind Main MapPage to another user control , my user control have only XML no CS codes,
UserControl Codes
<esri:Map x:Name="MyMap" WrapAround="True" Extent="-15000000,3600000,-11000000,5300000" Background="White">
<esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
  Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
        </esri:Map>
        <Border  BorderThickness="1" CornerRadius="5"
            HorizontalAlignment="Right"  VerticalAlignment="Top"
            Margin="0,10,48,0" Padding="5"  Width="300" >
            <ListBox x:Name="MyList" ItemsSource="{Binding ElementName=MyMap, Path=Layers}">
                <ListBox.ItemTemplate>
                    <DataTemplate>
                        <StackPanel Orientation="Horizontal">
                            <!--Layer visibility checkbox-->
                            <CheckBox IsChecked="{Binding Visible, Mode=TwoWay}" />
                            <!--Opacity slider-->
                            <Slider Margin="-5,0,0,0" Minimum="0" Maximum="1" Width="195"
                                Value="{Binding Opacity, Mode=TwoWay}" Height="18" />
                            <!--Layer name-->
                            <TextBlock Text="{Binding ID, Mode=OneWay}" Margin="5,0,0,0" >
                            <!-- Tooltip on hover-->
                                <ToolTipService.ToolTip>
                                    <StackPanel MaxWidth="400">
                                        <TextBlock FontWeight="Bold" Text="{Binding CopyrightText}" TextWrapping="Wrap" />
                                        <TextBlock Text="{Binding Description}" TextWrapping="Wrap" />
                                    </StackPanel>
                                </ToolTipService.ToolTip>
                            </TextBlock>
                        </StackPanel>
                    </DataTemplate>
                </ListBox.ItemTemplate>
            </ListBox>
My Map Page Map Codes for Map is
<esri:Map x:Name="myMap" Width="Auto" Height="Auto" Progress="MyMap_Progress" ExtentChanged="MyMap_ExtentChanged" IsLogoVisible="False"   MouseMove="MyMap_MouseMove" Margin="0,70,0,0" >
            <esri:ArcGISTiledMapServiceLayer ID="Carto1"
                      Url="http://localhost:6080/arcgis/rest/services/Carto1/MapServer"/>
            <esri:GraphicsLayer ID="MyGraphicsLayer" />
i use MapControl Var for map page map control , but i using LayerList Sample which have no C# codes
DominiqueBroux
Esri Frequent Contributor
Sorry I don't get what your issue is.
The sample you pointed out is working well. What do you want to change in the sample that is not working?
Asgharkhan
sir , i use Different user Control , Sample only working on my current user  control not in Main Map , i want bind this user control to my main Map Page , Layer list Sample is only xml Based . how i use MapControl Var in xml. or how i bind widget user control to main map page?
