bind FeatureLayer to other controls
1094
09-29-2010 09:45 AM
DaveOrlando
Hello, looking for some guidance,
I have a FeatureLayer and MapTips working fine. The MapTips are a 'mini' report of only a few attributes with a button to open a 'full' report.
I have been able to bind items (textblocks) from the mini into the full, but obviously they would have to exist in the mini first.
I would rather bind my full report directly to the FeatureLayer. Can this be done straight from the xaml, or would I have to, on the button click make an event to dump the results to something, then bind to that? I have set the DataContext of the full report to the FeatureLayer but no results come across.
Thanks in advance.
DaveOrlando
...some progress
from the button click on the MapTip I am executing a query to return all the attributes of that feature to then bind into a full report, as outlined above. For now the query where clause is hardcoded because I'm having trouble pulling any attribute (textbox) from my maptip into code behind.
kind of a rookie questions, but how can I access one of the maptip's attributes in code to then run the query.
I have tried:
string str = MapTipTitle.Text.ToString(); thinking that I could access it directly but no go.
DaveOrlando
for those who are interested........
private void btnOpenReport_Click(object sender, RoutedEventArgs e)
            QueryTask queryFL = new QueryTask("http://xxx/MapServer/29");
            queryFL.ExecuteCompleted += new EventHandler<QueryEventArgs>(queryFL_ExecuteCompleted);
            queryFL.Failed += new EventHandler<TaskFailedEventArgs>(queryFL_Failed);
            FeatureLayer tmpFL = MyMap.Layers["FLParcels"] as FeatureLayer;     // ! ID, not x:Name !
            TextBlock tmp = tmpFL.MapTip.FindName("MapTipTitle") as TextBlock;
            String strFolio = tmp.Text.ToString();
            Query query = new Query();
            query.OutFields.Add("*");
            query.Where = "folio = " + strFolio;
            queryFL.ExecuteAsync(query);
            bool bVisible = slPanel.IsVisible;
            if (bVisible)
                slPanel.Visibility = Visibility.Collapsed;
            else
                slPanel.Visibility = Visibility.Visible;
        void queryFL_Failed(object sender, TaskFailedEventArgs e)
            //throw new NotImplementedException();
            MessageBox.Show("Query failed: " + e.Error);
        void queryFL_ExecuteCompleted(object sender, QueryEventArgs e)
            FeatureSet FSresult = e.FeatureSet;
            // target in full report
            textBox1.Text = FSresult.Features[0].Attributes["street_nam"].ToString();
by Anonymous User
Not applicable
in XAML your button
<Button Tag="{Binding [YourAttribute]}" ..../>
in Code Behide Button_Click
Button button = sender as Button;
string attribute = button.Tag.ToString();
Use Button.Tag you can bring anything to CodeBehide.
