Bind checkbox to visible layers on map
8806
11
04-20-2011 05:07 AM
by Anonymous User
Not applicable
Original User: Toosters
Hi
Can someone please tell me how to bind checkbox is checked to visible layers on map (not defaultvisibility on mapservice, IsChecked="{Binding DefaultVisibility}" ).
I'm using sublayer list example (interactive samples, 9.3 arcgisserver). I have got the listbox binded in code to chosen mapservice layer: listbox.ItemsSource = layerInfoArray. I have also got all, on map, visible layers(from selected mapservice) in a list: layer.VisibleLayers.ToList(). I want to bind theese layerids from visiblelayerlist to checkbox so that if i close sublayerlist and opens again checkbox.ischecked should then be binded to the layers that actual are visible on map(visibleLayers list).
Thankful for suggestions or examples
DominiqueBroux
Esri Frequent Contributor
Finally implementing a new view model class is not that complex and is a much cleaner approach.
I did it in the sublayerlist sample by adding a combox allowing the user to select the Layer whose the sublayers will be displayed.
Attached is the code and a screen shot
by Anonymous User
Not applicable
Yes this works!! 🙂
Thank you very much Dominique!!
