Best way to export Map with graphics layer and all its component to PDF or JPEG in ArcGIS API for Silverlight?
4183
12-02-2014 11:47 PM
GauriDeshmukh
Can anyone plz tell me how to do this exactly.As I tried different methods like using silverPDF  and some samples.
The problem with silverPDF is that I cant export graphics layer or other UI component.
Which is the best way to achieve this? Do I need to use any geoproccessing service or python script?
DominiqueBroux
Esri Frequent Contributor
There are 2 options:
  1. Printing at client side (sample😞 In this case you have to use a PDF printer driver to get a pdf file.
  2. Printing at server side (sample😞 In this case, the pdf file (or any other supported image format) is generated by a server geoprocessing service.
charlesreed
Gauri,
Have you heard of TerraGo Publisher? It is a server side application that allows you to create GeoPDF's. When the document is exported, it will include your graphics also.
