BaseMap tool & ArcGIS.com resources
2041
7
08-17-2012 02:00 PM
TerryGiles
I'm thinking about making a tool for my Silverlight app similar to the functionality of the 'Add BaseMap' button in ArcMap.  Watching the http requests in Fiddler while clicking that button in ArcMap you can see it makes calls to arcgis.com, similar to how ArcGIS Explorer Desktop does (specifically this - http://www.arcgis.com/sharing/search?f=json&sortField=name&sortOrder=asc&num=50&q=group:34ca4e3505f2...
This request returns a nice bit of JSON of the basemaps available, including a link to the thumbnail image which would be perferct for my idea.
Anyone know if there are any restrictions against using this kind of info from ArcGIS.com?
Thanks, Terry
DominiqueBroux
Esri Frequent Contributor
BasemapGalleryGroupQuery is just returning the groups that drive the gallery of basemaps, it's not directly returning the basemaps.
After getting the groups, you have to chain to another query looking for the items shared with the group.
Alternatively you can directly use SearchBasemapGalleryAsync which is doing that job for you.
DominiqueBroux
The Portal API, new at 3.0, is what you need to access web maps stored in arcgis.com (documentation)
There is a sample here : http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#PortalMetadata
TerryGiles
Thank you Dominique.  I'm just starting to migrate to 10.1 and v3.0 of the API so this is perfect.
TerryGiles
Hello again Dominique,
I upgraded to v3 of the API and am trying to use the ArcGISPortal class to accomplish what I described above.  I'm close but am missing something here.  I trying to use the PortalInfo's BaseMapGalleryGroupQuery to get an Enumeration of the basemaps, but my results are empty.  Can you take a quick look at the code below and let me know if this should work or am I going in the wrong direction?
            _Portal = new ArcGISPortal();
            _Portal.InitializeAsync("http://www.arcgis.com/sharing", (p, ex) =>
                if (ex != null)
                    txtMaps.Text = "Basemaps currently unavailable";
                    lbxBaseMaps.Visibility = Visibility.Collapsed;
                else
                    ArcGISPortalInfo pInfo = p.ArcGISPortalInfo;
                    SpatialSearchParameters param = new SpatialSearchParameters
                        QueryString = pInfo.BasemapGalleryGroupQuery  //QueryString is "title:\"ArcGIS Online Basemaps\" AND owner:esri_en"
                    p.SearchItemsAsync(param, (result, err) =>
                        if (err == null)
                            System.Diagnostics.Debug.WriteLine(result.Results.Count());   //Results is empty
                    txtMaps.Text = "Select a Basemap";
                    lbxBaseMaps.Visibility = Visibility.Visible;
Thank you,
Terry
DominiqueBroux
TerryGiles
Once again, thank you very much Dominique!
ArcGISPortalInfo::SearchBaseMapGalleryAsync is exactly what I was after.  Code below for those interested.
                if (ex != null)
                else
                    pInfo.SearchBasemapGalleryAsync(null,(items,err) =>
                        if (err != null)
                        else
                            lbxBaseMaps.ItemsSource = items.Results;
DominiqueBroux
You are welcome.
I didn't notice early but you are using the REST end point http://www.arcgis.com/sharing while the recommended is http://www.arcgis.com/sharing/rest (see Remarks section in doc).
Probably not a problem for what you are doing today but may be a problem for future.
Sidenote : As arcgis.com is the default URL, you could as well pass a null Url:
_Portal.InitializeAsync(null, (p, ex) => .......
TerryGiles
Revised code below, which incorporates
  1. Dominique's comment re: passing in null in the Portal's InitializeAsync method
  2. using a SearchParameters object in the SearchBasemapGalleryAsync call.  Otherwise only 10 results are returned (currently should be 12)
                if (ex != null)
                else
                    SearchParameters param = new SearchParameters();
                    param.Limit = 20;
                    pInfo.SearchBasemapGalleryAsync(param,(items,err) =>
                        if (err == null)
                            txtMaps.Text = "Basemap Options:";
                        else
