Area And Perimeter
9778
26
10-09-2010 10:31 AM
NathalieNeagle
I'm using this example and it works great  in the example with projection 102100 but I'm using projection 4326 WGS 1984 esridecimaldegrees and my numbers are way off can someone tell what I need to change
buthttp://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AreasAndLengths
I think it is here  but not sure
   private void GeometryService_AreasAndLengthsCompleted(object sender, AreasAndLengthsEventArgs args)
            //TODO: Geometry service not returning correct values, area unit seems invalid, may need to use data in
            //planar coordinate space
            // convert results from meters into miles and sq meters into sq miles for our display
            double miles = args.Results.Lengths[0] * 0.0006213700922;
            double sqmi = Math.Abs(args.Results.Areas[0]) * 0.0000003861003;
            ResponseTextBlock.Text = String.Format("Polygon area: {0} sq. miles\nPolygon perimeter: {1} miles.", Math.Round(sqmi, 3), Math.Round(miles, 3));
NathalieNeagle
I'm still in need of the question I posted eailer but no I ran into another problem so I was hoping if someone was kind enough to answer one maybe they have the knowledge to do both.
So I've implemented the "area and perimeter" (http://help.arcgis.com/en/webapi/silverlight/2.1/samples/start.htm#AreasAndLengths) and the "Line Length" (http://help.arcgis.com/en/webapi/silverlight/2.1/samples/start.htm#Lengths)
I've add a button to clear the graphics and switch back and fourth between the two but I can't seem to figure out how to get out of them.  I mean what do I need to call to get back to the normal mouse clicks....so the left mouse click stops drawing line or polys and can pan or zoom (like the default mouse actions.).....
NathalieNeagle
I just figured this out a second after I posted this question.  All I did was
 MyDrawObject.IsEnabled = false;
I'm still hoping someone can help me out with polygon area mis-calculations.
NN
NathalieNeagle
It seems like the perimeter area code is converting from meters to miles and sq miles and I need to convert decimal degrees to miles and sq miles.  I tried to change the caluclation but it doesn't work
Has anyone ran into this problem and solved it.  I would be super greatful.
Nathalie
ChristineZeller
I'm having the same issue as Nathalie and I'm stuck.
I've also implemented the Area and Perimeter tool and I�??m also using the WGS 1984 projection (spatial ref 4326, units esriDecimalDegrees).  Can someone help Nathalie and me out and  let us know what to change to calculate a somewhat accurate area and line lengths
Christine
ChristopherHill
When you are calling the GeometryService.AreaAndLengthsAsync() method are you passing the units of measurement you want returned? The unit of measurement is defined using a Enumeration of type LinearUnit. there are parameters for length unit and area unit that you can pass to the function. if you do not pass any paramters the area and lengths will return in units of Spatial Reference (in your case degrees)
example:
GeometryService.AreaAndLengthsAsync(myGraphics,LinearUnit.Meters,LinearUnit.Meters,null);
so if you are just calling GeometryService.AreaAndLengthsAsync(myGraphics) you are going to get area and lengths in degrees.
AreaAndLengthsAsync(IList<Graphic> graphics,LinearUnit lengthUnit,LinearUnit areaUnit, object userToken)
http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Geom...
LinearUnit Enum
http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Line...
NathalieNeagle
Hey Chris,
Thanks for your post so I'm think I'm really close.  I'm still getting really small numbers so I'm not sure if I'm missing something.
Here's what i'm doing.
        private void MyDrawObject_DrawComplete(object sender, DrawEventArgs args)
            ESRI.ArcGIS.Client.Geometry.Polygon polygon = args.Geometry as ESRI.ArcGIS.Client.Geometry.Polygon;
            polygon.SpatialReference = MyMap.SpatialReference;
            Graphic graphic = new Graphic()
                Symbol = LayoutRoot.Resources["DefaultFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol,
                Geometry = polygon,
            GeometryService geometryService =
                new GeometryService("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
            geometryService.AreasAndLengthsCompleted += GeometryService_AreasAndLengthsCompleted;
            geometryService.Failed += GeometryService_Failed;
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.Graphics.Add(graphic);
            List<Graphic> graphicList = new List<Graphic>();
            graphicList.Add(graphic);
 geometryService.AreasAndLengthsAsync(graphicList, LinearUnit.SurveyMile, LinearUnit.SurveyMile, null);
       ResponseTextBlock.Text = String.Format("Polygon area: {0} sq. miles\nPolygon perimeter: {1} miles.", Math.Round(args.Results.Areas[0], 3), Math.Round(args.Results.Lengths[0], 3));
Nathalie
ChristineZeller
Yea I'm still getting a really small number.  I tried it slightly different than Nathalie but sounds like the same results.  Do you know what I am missing.
                Geometry = polygon,
            geometryService.AreasAndLengthsAsync(graphicList,LinearUnit.Meter, LinearUnit.Meter, null);
NathalieNeagle
Christine,
Did you make any more progress.  I'm still stuck.
Nathalie
ChristopherHill
Both code samples are correct. Let me ask a few questions to pin point the problem you are both having.
Is the problem you are now having an issue with the lengths and area being returned do not seem to be the correct units? or are they correct units, but just seem to be off?
example: You request LinearUnit.Meters and it still returns Degrees? or You request LinearUnit.Meters and units are correct just the distances are off?
have you tried verifying your geometry against the rest service itself?
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer/areasAndLengths
do the areas and lengths return the same values when you test against the REST service directly?
