arcgisoutput folder is empty
1077
05-17-2010 01:15 PM
YingLin
I set the DynamicmapService output folder to be the arcgisoutput folder. There are subfolders with map service name created once you set up. however the folder appears to be empty. where all those temorary images stored on the server? I tried to get those images to build the print function.
Anyone can help? Thanks very much
dotMorten_esri
Esri Notable Contributor
The output folder is not used for the dynamic map service. Instead the data is returned directly in the exportmap REST request.
