API/viewer Template not loading in visual studio 2012 RC
2928
08-09-2012 12:47 PM
by Anonymous User
Not applicable
Original User: derklauer
I am running Visual Studio 2012 RC and expression blend 4 I am going through the silverlight API Getting Started tutorial and when I replicate the steps I am not seeing the ESRI template under the silverlight tree when I start my project.
I have installed both the silverlight viewer and the API exe.
Attached are screen shot.
the jpg titled "not working" is what I see and the other image is the screen shot that esri says I should see.
What am I doing wrong?
thank you
deleted-user-ATjHIWsdQYmT
Currently don't seem to be supported.
see this thread:
http://forums.arcgis.com/threads/63967-visual-studio-2012?highlight=2012
by Anonymous User
Not applicable
Original User: bettsdaniel
This is a big PROBLEM and I am going through the same thing
2 weeks later and ESRI is saying I should install on a new Machine
Evidently the REPLICATION of the CONFIG at ESRI
Showed the same problems on some machines ......not on others
I cannot proceed without this Funtionality
I am now LOBBYING for a new WORK STATION .......but cmon ESRI (this is 6 months later)
I do not see any RESOLUTION here ........did anyone ever help you find a solution or cause ?
