After putting measure action in code, which code show meansure action is completed?
1354
02-23-2011 11:09 AM
DanDong
Hi all,
I have put the measure action in code-behind.
MyMeasureAction m = new MyMeasureAction();  //initialize a MyMeasureAction class
            m.MeasureMode = ESRI.ArcGIS.Client.Actions.MeasureAction.Mode.Polygon;  //MeasureMode is polygon
            m.DisplayTotals = false;    //do not display total distance
            m.FillSymbol = LayoutRoot.Resources["DrawFillSymbol"] as FillSymbol;
            m.DistanceUnit = ESRI.ArcGIS.Client.Actions.DistanceUnit.Feet;
            m.MapUnits = ESRI.ArcGIS.Client.Actions.DistanceUnit.Feet;  //the unit of the map is Feet
            m.Attach(MyMap);    //bind this action to MyMap
            m.Execute();    //execute this action
But I don't know which piece of codes show that the measure action is completed. Dose it exist some function like measreCompleted event? I didn't find it in API.
Since I want to return the cursor to hand shape and return to pan mode after finishing this measure action, I want to know where I can add the codes....
Thank you all!:)
JenniferNery
You are right, there is no event raised when MeasureAction is complete. If you notice in the SDK sample, measure is completed when a DoubleClick is detected. This is when graphics are cleared from the map, which might be a good time to re-enable the pan cursor.
Point lastClick;
private void Map_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
 Point pt = e.GetPosition(null);
 if (Math.Abs(pt.X - lastClick.X) < 2 && Math.Abs(pt.Y - lastClick.Y) < 2)
  //TODO: change cursor here
 lastClick = pt;
DanDong
Point lastClick;
 lastClick = pt;
Thank you Jennifer! I also try to change cursor shape in LayerCollectionChanged event. That also works.
DidarBultanov
Point lastClick;
 lastClick = pt;
how to make that graphics would be kept on the maps?
Tanks
JenniferNery
It is by design that the graphics created by MeasureAction are removed from the map upon completion.
However, this related thread might help preserve the graphics on the map: http://forums.arcgis.com/threads/13902-about-after-using-measure-behavior-the-graph-can-t-stay-in-th...
